engine
Old Sep 23, 2012 | 03:58 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
engine
1985 iroc tpi 305 has 215 hp a 1987 350 tpi has 220 hp why does everybody say dump the 305. i going to rebuild my 305 tpi because 5 hp is not that much more. and maybe with a diffrent cam than stock i think it could give me 5 to 10 hp more. the cam i am looking is SPEED PRO CS1014R 204/214 DUR @ 50 .420.443 LIFT. what do all of you think.
Old Sep 23, 2012 | 04:11 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: engine
I think it's a waste of time.
Regardless of what your factory ratings may or may not be, you will generate more torque and more power at a lower RPM with the bigger motor if all other factors remain the same.
Old Sep 23, 2012 | 06:21 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engine
Forget the factory ratings. Even if you're leaving the 225 HP 350 ( NOT 220 ) pure stock, it has 10 more peak HP, but far more average HP. The torque is the reason, the torque is what you drive, what you feel. Wrong cam for either one, but the 350 will give more improvement from a cam swap, if your choice is a proven upgrade. The cam you chose WILL cost you enough lower-RPM torque that you WILL feel the loss. By the time you buy the cam, and gaskets, and pay shipping, you could have a good used 350 for the same investment.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
