Front intake gasket
Old Sep 23, 2012 | 06:53 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Front intake gasket
Probably not but worth a shot at asking. Is there a way to fix or redo my front intake gasket w/o having to completely take off the intake? I just rebuilt a motor and I used the felpro gasket kit which had rubber front and rear intake gaskets (which I know now that I should have chunked in the trash) and the front one has split from the intake being torqued down so the oil is leaking out of it and going all over the place.
Old Sep 23, 2012 | 07:40 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Front intake gasket
I had this once and took a couple tubes of red rtv silicone and gooped it all over the front. Looked ugly but didnt leak anymore.
Old Oct 3, 2012 | 09:24 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Well, good new and bad news.
Good: It isn't leaking from the intake.
Bad: It's coming from the timing cover.
Used a dye and UV light and found it.
Old Oct 3, 2012 | 09:38 PM
dlinger's Avatar
Car: 1984 Z28 HO
You can try cleaning the area with carb cleaner. Use your finger to spread silicone seal where it is leaking.
Old Oct 3, 2012 | 10:18 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i have used the exact method described above to fix leakey intake manifold end seals-worked great and lasted for years
Old Oct 4, 2012 | 02:00 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Goop in the silicon and see if it holds. If not, worst it's gonna do is leak and you'll have to pull the timing cover anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
