Turbo on a 305 tpi
Old Sep 26, 2012 | 12:42 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Turbo on a 305 tpi
I have the 5 speed 305 tpi on my gta and I want to give it more punch and I've been wanting to do that by sticking a turbo on it but I'm just wondering if it's doable. I know that the manual transmission didn't come with the 350 because the torque would wreck it, would this be the same case if I put a turbo on the 305?
Old Sep 26, 2012 | 12:38 PM
T/A's Avatar
T/A
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
Re: Turbo on a 305 tpi
from what i've heard about T-5s, you may have to be careful, depending on how much boost you plan on putting out. also the can the engine handle it? how much boost are you thinking of?
Old Oct 29, 2012 | 07:50 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Drag slicks, drop the clutch at the drag strip, T5 will break...
Street car with less traction / not sticky tires, can last...
I met a guy with 400+ HP on his street car with a T5, had it for 3 years no problems...
I have a 305 TPI with a T5 also... getting a BBS turbo header hopefully within 2 weeks
Rafael
Old Oct 29, 2012 | 09:23 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
T5 a tossup. Seen some scatter with not so heavy use, friend had one in a heavy 57 wagon with a stout 383 and pounded on it no issues.
Turbo on a stock bottom end?
Old Oct 29, 2012 | 10:02 AM
1gary's Avatar
Honestly never built a turbo 305,but I do have a passing fascination about them.I have read alot about them.So I will be looking forward to your build thread.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
