Timing chain replacement,help needed
Old Nov 10, 2012 | 07:31 AM
  #51
momplo's Avatar
Car: Trans Am GTA 1988
Engine: v8 5.7L 350 tpi
Axle/Gears: Dont know what this is yet :)
Re: Timing chain replacement,help needed
alright update time: I'm sorry, I was a complete idiot about the "can't turn the crank thing" because I was trying to turn it by grabbing the damper or using a SMALL ratchet on the crank bolt. I went and bought a 3 feet bar with a ratchet at the end ( I don't know how you call it) plugged it on the crank bolt and it turned, even with all the spark plugs in. I lined the dots perfectly at 12-6, turned the crank 4 times and they were back to 12-6, so there is no possible mistake on the gear emplacement or setting. I just put everything back together, the battery is under charge, fingers crossed, I don't see how it could go wrong with a fully charged battery and perfectly aligned gears with everything put back together the exact same way it was.
Old Nov 10, 2012 | 01:12 PM
  #52
Just don't forget, dot-to-dot is #6 firing, not #1 firing. Both dots up, which is one full crank revolution from there, is #1 firing. Set your distributor up accordingly. Get that right, and all will be well.
Old Nov 14, 2012 | 12:22 PM
  #53
momplo's Avatar
it works !!!! Finally I can go and store it for the winter haha i wasted my last days of beast driving this year
specialized
Jun 18, 2022 09:26 AM
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
MY87LT
Aug 17, 2015 08:43 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
