1991 tbi 305
Old Sep 29, 2012 | 01:09 PM
dbenjamin's Avatar
Car: 1991 rs camaro
Engine: ls1
Axle/Gears: 10 bolt
1991 tbi 305
so for the last few weeks my car hasnt been wanting to start , it will start sometimes but othertimes ill be stuck in a parking lot for 1 hour to almost 3 hours i dont really know anything about the car since ive only had it for a few months ,everything seems to be stock besides the radio fan and exhaust.
Old Sep 29, 2012 | 03:43 PM
ex-x-fire's Avatar
Re: 1991 tbi 305
Does it crank or not. If it cranks & does not start, look to see if the injectors are spraying, see if you have spark, & if you don't see injectors spraying you'll have to get a noid light & a fuel pressure tester.
If it doesn't crank, check for power at the starter & check the battery connections & grounds.
Old Jan 7, 2013 | 03:01 AM
dbenjamin's Avatar
Car: 1991 rs camaro
Engine: ls1
Axle/Gears: 10 bolt
Re: 1991 tbi 305
I got it to work i clean the tbi up a little bit and its fine now, thanks for the help!
jhawkeye
May 25, 2022 06:33 PM
deracer
Apr 11, 2016 12:04 AM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
