Testing distributor
Old Jan 6, 2013 | 11:18 PM
zzjakect's Avatar
Car: 1985 Z28
Testing distributor
How does one go about checking the distributor? I need to find out if it is getting power. Where does the power enter dizzy? Where is the ECM located? 1985 z28 with 350/TPI automatic. There is no external coil on this engine. What would be the proper pickup coil resistance? If the resistance is right can it still be an issue?
Old Jan 7, 2013 | 06:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Testing distributor
Originally Posted by zzjakect
How does one go about checking the distributor?. What would be the proper pickup coil resistance? If the resistance is right can it still be an issue?
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Jan 7, 2013 | 06:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you have a HEI dist with the coil in the cap then the Ign power wire is the pink wire to terminal on side of dist cap
should have 12V on it with the key on
Old Jan 7, 2013 | 07:48 AM
zzjakect's Avatar
Car: 1985 Z28
thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
L98GTA87
Oct 19, 2015 10:43 PM
camarohelp
Sep 22, 2015 03:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
