GTA intake plenum
Old Sep 30, 2012 | 06:32 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
GTA intake plenum
DOES ANYONE KNOW A TRICK TO GETTING THIS F@#$%% INTAKE PLENUM OFF? I UNHOOKED EVERYTHING AND IT IS LIKE CEMENTED ON. I HAVE TO REPLACE MY FPR AND THIS THING IS GIVING MY A STROKE
Old Sep 30, 2012 | 06:41 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: GTA intake plenum
If you have all of the bolts out for sure, sometimes they need a good smack to break the gaskets free.
Old Sep 30, 2012 | 07:24 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
good ol rubber hammer should do it
Old Sep 30, 2012 | 10:00 PM
GTA387's Avatar
Car: 1987 GTA
Engine: 5.7
Is anything attatched to the plenum underneath that I might not see? Hit it on the front or back? I also wanted to mention I didnt loosen the bottom runner bolts because my limited amount of tools prevents it.
Old Sep 30, 2012 | 10:46 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There are some vacuum lines and wires, but nothing physically holding it except the runner bolts. Remove the throttle body, stick a bar in the front and pop up the plenum to loosen it.
Old Sep 30, 2012 | 10:53 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You hafta loosen the runners to intake bolts because the gaskets have "pegs" that insert into holes in the plenum. Until the runners can lean outward & widen the gap for the pegs to come out? The plenum is not coming out. I encountered this the last time I had to pull mine.
Old Sep 30, 2012 | 10:57 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No, you do not have to loosen the lower bolts. The runners are long and made of thin soft aluminum. They will easily spread just enough without damage to allow removal of the plenum.
Old Sep 30, 2012 | 11:05 PM
Car: GTA
Well.....I can tell you 1000% that MINE would not come loose until I loosened the runners. No ifs ands or buts about it. The gaskets had plastiuc plugs. No rubber mallet moved them. Nothing did. Nothing until I loosened the runners.
Perhaps you've never encountered good gaskets. Perhaps yours were simple flat "paper"/cork gaskets. I dunno.
But what I do know is that possibly his have the plastic plugs to position them. I certainly wouldn't want him damaging his aluminum stuff trying to move something that isn't gonna move with damage being done.
I certainly wish that mine would have moved but they wouldn't.
Old Oct 2, 2012 | 10:12 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The pointy side of the little plastic nipples are designed to hold the gasket on the runners so they won't slide away. The other side of the plastic nipples are flat so that they are flush with the gasket mating surface, allowing the plenum to be raised and lowered. The gaskets can even be reused if they aren't ripped.
Old Oct 2, 2012 | 11:15 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Right. The plugs fit into holes in the top of the runners. You can smack the plenum pretty much anywhere on a flat surface with a rubber mallet and it'll break loose. I say pretty much, because it may depend on your runners. My SLP runners make the plenum sit literally paper-width apart from the EGR on top of the intake base. The first time I had to break down my TPI setup with SLP runners, I couldn't understand why it wouldn't break free from hitting it with a rubber mallet. If you hit at the very front or very back, it'll break loose at an angle, making one end pop up.
MantyZ28
16
Dec 21, 2015 11:02 AM
Thaney9
Aug 29, 2015 03:16 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
theurge
Aug 21, 2015 12:46 PM
