New 350 build
Old Oct 10, 2012 | 03:18 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
New 350 build
Hey everyone im in the process of doing a top end rebuild i recently dropped my 355 down at my local machine shop i took my heads, cam, intake off an thats it so it would come out cheaper for the rebuild. I ordered my holley stealth ram vortec base intake setup an also dropped off my 906 vortec heads with the block . with the vortec heads im gonna get them opened up to 2.02 intake valve for more air intake. The block that i got is a pre 86 4 bolt main with a right hand dipstick 2 piece rear main seal with a hydraulic cam wish i had the roller block design block. Im looking to get a decent cam but dont know where to start looking the hsr intake has a rpm range of 1000-5500 rpm so im guessing a cam in that range would be dead on perfect. Also for fuel delivery im running venom 30 lbs injectors which are rated up to 385hp which is right in my ball park. So my question is what cam can i use with the setup im mostly looking into comp cams, lunati, an howards cams it also seems trickflow makes good power range cams as well. My block will be done in a couple of weeks an be ready to be dropped in by december after christmas an will be at the dyno tuning shop in January
Old Oct 10, 2012 | 07:48 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: New 350 build
Call Comp Cams... you will not get better advice and more support over the phone.
Old Oct 10, 2012 | 09:46 PM
Engine: LR4 4.8
Re: New 350 build
Ok ill give them a call an see what they have to offer they are my number one pick at the moment followed by trickflow there prices seem real fair also for a good aftermarket cam
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
