What will these heads support?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I was curious what kind of power a stock set of 601 heads will support.
I have a .030" over 305 TPI with full intake and exhaust, roller rockers and some other mods.
I'm currently not impressed with the way the motor just shuts down at 4500RPM. I believe the rebuild company used the peanut cam.
I want to do a Cam swap but don't want to motor to still die at 4500rpm because the heads are holding everything back.
Re: What will these heads support?
The TPI lays down at around that RPM.
The heads themselves will flow about 375 HP or so, with decent porting; maybe closer to 400. No way TPI will support that though, its "tuned" function defeats any degree of higher RPM operation, thereby limiting HP.
Car: 1985 Z28
https://www.thirdgen.org/forums/atta...405_131547.jpg
https://www.thirdgen.org/forums/atta...325_202936.jpg
This intake is capable of making power well past 4500 with the right cam.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Did you forget the TPI 383 with the 212/218-110 cam Extrude-Honed aluminum L98 heads and extrude-Honed TPI doing 458 HP @ 6200 RPM? Stock TPI is happy to 4800 on a 350. 305 should do 5000 with NO mods. Swirl-port heads and "peanut cam" together do peak around 4000, but I myself have spun that combo to 6200 in first in a stock LO3. That is, admittedly, not TPI, and it was with a worn timing chain and a muffler upgrade, but still, it evidences adequately that even the worst 305 should happily pull well past 4500, suggesting a partly-clogged catalytic converter, or a weak ignition coil, or both, or who-knows-what?
Car: 1985 Z28
Catalytic converter could be a possibility IF I had one. I'm running an accel supercoil and the distributor still has a JEGS module in it from a P/O.
ambainb
Apr 25, 2016 09:21 PM
Magman
Sep 12, 2015 10:43 PM
509 camaro fan
Sep 6, 2015 10:43 AM
