Timing contol
Old Oct 14, 2012 | 06:52 PM
Austin358's Avatar
Timing contol
I want to run nitrous. Need a way to control timing. Vehicle is already tuned. Stock 91 ECM with Ed wright tuned. Don't won't a separate prom and tune for it.
Old Oct 15, 2012 | 07:31 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Timing contol
Use a NOS controller that controls the NOS flow
( ramps it up to 100% instead of dropping it all in at start like a off / on switch does ) ,
retards the timing and has rev limiter all in one unit
http://www.jacobselectronics.com.au/nitrous.htm
http://www.chevyhiperformance.com/te...xide_controls/
Old Oct 15, 2012 | 09:29 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Timing contol
I think the Mallory 685 ignition box is the simplest, most economical way of controlling a single stage of nitrous. It will provide your selected spark retard when triggered by the nitrous circuit and has a built in window switch to avoid bringing the shot in at too low of rpm; can also use the top end of the window switch to cut the nitrous before each shift if you don't have a solid built auto.
Anything up to a 150 shot single stage, I wouldn't use a progressive controller. It's not needed if the rest of your car is set up correctly, and most solenoids are not designed to handle the pulsing.
Old Oct 15, 2012 | 04:06 PM
Austin358's Avatar
Re: Timing contol
Thanks guys
Old Oct 15, 2012 | 04:09 PM
Austin358's Avatar
Re: Timing contol
Anybody running the nos kit made specifically for the tuned port?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
