Should I install 7mm spark plug wires even if stock?
Old Oct 15, 2012 | 04:10 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Here's my dilemna:
I'm just a few steps away from completing a full tuneup on my car and learned that the stock part number for Delco wires fitting my car is 708Q.
I ordered and received them from Rock Auto, however, when I opened the package, the wires are clearly marked as being 7mm.
This car is 'fair weather only', but has had some minor performance upgrades over stock (exhaust, K&N filters, air foil, MSD coil, shift kit etc). I've heard that 8mm and even 8.5mm are better choices, so here's my question:
Will the 7mm work fine without me noticing any difference, or, is there a Delco part number I should be using instead, specifically for my engine?
Thanks in advance!
Old Oct 15, 2012 | 04:46 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Should I install 7mm spark plug wires even if stock?
They'll be fine. If they aren't cross-firing, arcing or able to shock you when you touch the wire, then they are thick enough. Making the insulation thicker is not likely to add any benefit immediately. It might last longer. There are many other things that can be done to the wire to actually make a large difference in performance without changing the thickness of the insulation.
Old Oct 15, 2012 | 08:54 PM
majobis's Avatar
Axle/Gears: G92
Thanks for your response. I could have sworn I had seen that part number somewhere as being a performance upgrade over the base wires. Probably just a marketing gimmick.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
djmarch
Aug 9, 2015 05:27 PM
