More Engine Help...0psi Compression
Old Oct 16, 2012 | 08:33 PM
nbanwart's Avatar
Hello again guys,
So after I finally put a new crank in with matched bearings, with around .0015-.0020 on rods and mains according to plastigage. Now all the engine does is turn over. Has gas, has spark. Doesn't even try to start. No compression. Literally. 0 frickin psi in #1 cylinder, and I'm assuming in the rest as well. What in the hell could cause this? Engine had low oil pressure because I forgot the galley plugs, do I need to reset valve lash? I bought a new timing gear and set it at the special "magical" 4* advance the box recommends I do...lined up the dots etc. What is going on?
Thanks in advance for the advice and for listening to my whining
Old Oct 16, 2012 | 08:43 PM
Re: More Engine Help...0psi Compression
Sound slike the valves are all too tight.
Back em all off 3 turns and try again.
Old Oct 16, 2012 | 11:10 PM
1gary's Avatar
In case like me didn't remember your thread from before..................
https://www.thirdgen.org/forums/tech...d-low-oil.html
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
