Fuel Filter Change
Old Oct 16, 2012 | 08:56 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.42 POSI
Fuel Filter Change
I changed my fuel filter the other day and had some issues. Now I removed the gas cap to relive pressure and disconnected the battery so the pump wouldn't turn on. Does anyone know why fuel would keep coming and not stop?? I lost two gallons and didn't have much left in the tank when I was done.
Old Oct 16, 2012 | 09:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Fuel Filter Change
It's normal in my experience. But two gallons is a bit much even if you were doing it as slow as molasses.
Old Oct 16, 2012 | 10:06 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
There's no way you lost 2 gallons of fuel by changing a fuel filter. Fuel will come out of the lines now that you've removed the filter because they're being drained. The reason you disconnect the battery is so you don't ignite anything and become a fireball. The fuel pump will not come on if the car is off.
Here's what i do:
1) disconnect battery
2) remove gas cap to vent pressure out of the tank.
3) go to the engine, find the fuel test port (or fuel line, sorry not familiar with TBI) and with a rag, relieve the pressure in the rail and lines (by doing this, it doesn't mean the lines are bone dry. There's still unpressurized fuel sitting in the lines. This will come out when the filter is removed.)
4) Go under the car and crack open the filter fittings. Watch your eyes and face as fuel will probably squirt out.
5) let lines drain out. It may seem like a lot, but it barely filled the bottom of my black oil change pan.
6) once lines have drained out, clean up line fittings if they're dirty/rusty (don't use anything that will make sparks!). Install fuel filter and reverse the directions.
Old Oct 17, 2012 | 07:12 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
I know it was two gallons because I had a gallon can underneath the car and had to empty it twice. Yes it was a slower rate as I did not jack the car up much.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
maroe624
Apr 16, 2017 08:29 AM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
