Need Help with Upgrades
Car: 87 Chevy Camaro Z28
Engine: Carb LB9 Converted
Transmission: Stock 700R4
Axle/Gears: Stock
Alright my Fellow TPI Friends I need your help i'm going to replace my timing chain and I wanted to know whats a good timing chain and should I go with a stock OEM or with the double roller one. Which brand would be good on a 305 TPI. And whats a good water pump and a radiator.
Thanks for your help
Chris
Chris
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Need Help with Upgrades
I vote for a Cloyes double roller. That's what I have and no trouble at all with it.
Axle/Gears: Stock
Which Cloyes Double Roller did you get street true or true roller and whats the part number thanks for your help.
Thanks,
Chris
Thanks,
Chris
dbrochard
Sep 25, 2015 04:56 PM
