Subtle differences
Old Oct 20, 2012 | 12:07 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
Transmission: BW super t10
Subtle differences
I am swapping my Crap-O-Five out with a 350 that i rebuilt and i noticed a few differences when i go to drop it in. First off my fuel pump only has 2 lines on it and my 305 had 3. Is one for the EGR? Secondly, my water pump has a pipe plug installed where the 305 wp has a port for connecting a hose. Do i need to remove the pipe plug and put that hose connection on it?
Old Oct 20, 2012 | 12:17 PM
Re: Subtle differences
Don't even bother.
Take everything off of the 305 that's different from what's on the 350, and put the 305 things on the 350.
Old Oct 20, 2012 | 12:21 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
My 305 fuel pump got smashed so i had to replace it and the WP was all rusted internally from sitting for so long. I removed the motor and deployed and life happened and blah blah blah. Plus i have already installed both parts on the block.
Old Oct 20, 2012 | 12:46 PM
A fuel pump is like $12.
Go buy THE RIGHT one.
A water pump is like $15 or something.
Go buy one of those, too.
Still costs you less than the oil you're going to pour in it. IOW, chicken feed, WAY down in the noise level of the project as a whole.
6 bolts and they're uninstalled. 15 seconds. 30 seconds to put em back. In the time it took you to argue, you could already have been finished swapping em out.
Old Oct 20, 2012 | 02:43 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
i already bought new ones and its nbd i need a different FP. But the port on top the WP i cant just swap out the pipe plug with the port? what does that port even go to?
Old Oct 20, 2012 | 05:43 PM
Heater core... hot water TO it comes out the intake (the hot side of the motor), cooled water returning FROM it comes back either into that port, or the port in the cold tank of the rad. So yeah, if your cold heater core hose goes to the rad, you can put a plug in the WP one.
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
