Running rich fouling plugs please help
Old Oct 21, 2012 | 08:31 PM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I have a 350 tpi bored .030 over with stock crank and heads and a high rise cam when it's running I have black smoke out tail pipes a d the plugs are covered in fuel would the big cam cause too much fuel to enter the chamber and flood the plugs? Car runs and drives just have a lot of black smoke and have to change plugs out once a month
Old Oct 24, 2012 | 06:01 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: Running rich fouling plugs please help
is the CTS working? if it's reading a cold engine, you're gonna dump fuel in there...
Old Oct 24, 2012 | 06:13 AM
ex-x-fire's Avatar
Is it map of maf? If map, check for the proper vacuum hose connection.
If maf, try cleaning it.
Check fuel pressure & bleed down rate.
Make sure the ign. timing is right. Double check all the ground wires near the firewall, there are for the ecm.
You might need programing w/ that cam. Tpi engines like certain types of cams, you shouldn't cam them like a carb engine. Whats the cam specs?
eightsixseven
Dec 16, 2024 01:50 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
squiggy2
Aug 9, 2015 09:30 PM
