Your next engine swap...
Old Oct 25, 2012 | 12:54 AM
DonutGuard's Avatar
Car: '84 TRANS AM
Engine: 5.7L SBC
Transmission: TH700R4
Axle/Gears: Stock 3.73 Posi
General Motors just announced the latest Ford Fryin', Mopar Maulin', Import Incineratin' engine... the all-new LT1.
Here are some specifics and quotes from the LSTech forum, then I'll just let you guys read the articles
6.2L Displacement
11.5:1 Compression Ratio
450+ Horsepower "At least 20hp more than the LS3"
450+ ft-lbs Torque "At least 26 ft-lbs more than the LS3"
Estimated 0-60mph in less than 4 seconds in the 2014 Corvette
26+ MPG Highway
Gasoline Direct Inject Technology
Variable Engine Displacement Technology
Engine will be built in the Tonawanda Engine Plant, which is where the original 1955 small block was built. Engine is 99.9-percent new.
2014 Corvette will have 450/450 preliminary rating, 465-pounds. "More than 26 MPG".
11.5:1 compression
Direct injection system hidden under the intake manifold. Injector flow rate is 22.0cc/s@10MPa, up to 2,175psi (15MPa). 65-volt fuel injector controller. Highest flowing pump on the market and it is driven off of the camshaft with a unique lifter system. Each injector has 6 holes and they are all angled.
Increased based displacement allows the engine to stay in 4-cylinder mode more often, resulting in more power and torque with increased fuel consumption. 62 crank degrees of cam phasing authority on the CVVT camshaft. Four-into-one cast short-tuber header, that is nearly equal length.
Variable-displacement oil pump will adjust oil flow to maintain proper oil pressure at the bearings. 50-75kpa lower oil pressure than the Gen4 LS engine. Wet and Dry sump available.
"Swapped intake and exhaust"
"One VERY big intake and one modestly sized exhaust valve"
"Twisted shaped high-flowing intake and exhaust ports"
"Centralized spark plug"
“Buried the pump and injectors in the valley to reduce 'click' from the DI system at idle.”
“Deck height is the same, rod length, stroke and bore are the same. Crank to cam centerline are the same."
"We hope it is very difficult to crack the computer code."
"There will still be LS crate and service engines being built. No more further LS engine development."
Jalopnik Article
Autoblog Article
Picture Gallery
Another Jalopnik Article... this one with the LT1 on the Dyno!
Old Oct 25, 2012 | 07:56 PM
DonutGuard's Avatar
Car: '84 TRANS AM
Engine: 5.7L SBC
Re: Your next engine swap...
112 views, no comments? Here, have an awesome animation of the engine.
Old Oct 25, 2012 | 08:38 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Ok i'll comment
This is very good news. Personally im most excited because it will eventually drive down the prices of ls motors, making them possibly a budget option.
Any word on its weight? 4 cylindar mode is interesting to me, I hope it doesnt become one of its faults. Good displacement too. I cant wait to see it after a hot rodder gets ahold of it and tweaks it.
Old Oct 25, 2012 | 09:18 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Looks like I have something to save for after I get out of college soon. Nice!
Old Oct 26, 2012 | 04:22 PM
DonutGuard's Avatar
Car: '84 TRANS AM
Engine: 5.7L SBC
Originally Posted by blue birdy 87
Ok i'll comment
I read more into it, apparently the Variable displacement is something that they're doing with the oil pump. I guess the oil pump is computer controlled and can pump up more oil when it's required? What it's using is Variable Valve Timing... so I would guess a solenoid will advance or retard the cam timing on demand depending on the engine's needs.
The only thing I've read on the weight is that it's 40 pounds lighter than BMW's 4.4L Twin Turbo V8, as well as 4 inches shorter. I've tried looking up how much the 4.4L weighs, but I've found nothing.
I did find however, a full spec sheet (I'll link where I found that at the bottom) and an article from GM outlining the engine.
Originally Posted by Spec Sheet
Gen 5 Small Block LT1 Specifications
Engine type: 90-degree V-8 with overhead valves; continuous VVT
Displacement: 6.2L (376 cubic inches)
Bore x Stroke (in / mm): 4.06 x 3.62 / 103.25 x 92
Cylinder block: cast aluminum with nodular main caps
Main bearing fasteners: six, including two cross-bolts per cap
Crankshaft: forged steel
Connecting rods: powder metal, 6.125 inches in length
Pistons: eutectic aluminum alloy
Compression ratio: 11.5:1
Cylinder heads: 319-T7 cast aluminum with 59.02cc combustion chambers
Valve angles (degrees): 12.5 intake, 12 exhaust
Intake valves: 2.13 inches (54mm) hollow
Exhaust valves: 1.59 inches (40.4mm) hollow sodium
Camshaft: Hydraulic-type with tri-lobe for fuel-pump drive
Camshaft lift: 0.551-inch (14mm) intake / 0.524-inch (13.3mm) exhaust
Camshaft duration: 200-degrees intake / 207-degrees exhaust (at 0.050-inch)
Lobe separation angle: 116.5 degrees
Fuel delivery: direct injection
Intake manifold: “runners in a box” design; composite construction
Throttle: 87mm electronically controlled throttle body
Ignition: 58X with individual coil-on-plug and iridium-tip spark plugs
Horsepower / kW: 450 / 335 (estimated)
Torque – lb.-ft. / Nm: 450 / 610 (estimated)
Max. engine speed 6,600 rpm (fuel cutoff)
GM's Announcement page.
Media website with Adobe fact sheet links about the engine.
A new article from GM High Performance Magazine.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
