ICM Symptoms
Old Oct 25, 2012 | 04:31 PM
perschken's Avatar
Car: 91 Firebir Formula
ICM Symptoms
Have a rebuilt 350 TPI and it has a slight miss. The miss is mostly noticable when it is revved in nuetral. Does it when engine is hot or cold, I also noticed that it cranks over a little longer before firing up than it ever used to (only by 2 seconds or so). It almost feels to me like timing because it presents itself as a vibration, but timing is at 6 degrees BTDC. Also has new cap rotor, wires, and plugs.
My question is could this be a bad ICM issue. I thought if an ICM was bad it either ran or didn't, or symptoms would only occur when hot.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
MM2Robinson
Oct 1, 2017 09:16 AM
racereese
Oct 3, 2015 03:46 PM
