Things i need to make car street worthy?
Old Oct 28, 2012 | 05:14 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
I for sure need a battery, alternator, and some headers. (current headers are warped)
The emissions stuff on th driver side their a little canister with a line coming from gas tank. how do i remove this and what do i do with the line?
i ordered a new pcv valve and grommet im using the driver side pcv for the carb. their is one more hole in passenger side valve cover for a pcv or something. DO i just put a breather?
my brakes no longer work the pedal is super hard and i cant stop car even when cruising like 10 i hooked up the brake booster line to manifold vacuum directly to a port on the manifold. Do i need a new booster?
what do i need to make the tranny shift? I need to hook up the tv cable but i dont have the bracketry i have a edelbrock 1405 carb 600cfm
IS the engine supposed to have smoke coming out from carb? I ran the engine for like a couple iof minutes and theres smoke coming from pcv holes and carb when i have filter off. Is that normal? Its a new carb and dist. oil is full and im getting oil to rockers.
Old Oct 29, 2012 | 09:45 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: Things i need to make car street worthy?
Why are you trying to remove that line/canister in the first place?
Yes, you can just put a breather in there.
For the booster issue, first check to make sure that vacuum is coming from wherever you have the booster line going to. and check the line itself, it could probably just be a vacuum leak.
Your new PCV should take care of the smoke coming from the absence of one. Run your car for longer than a couple of minutes to see if smoke subsides from coming out of your carb...Hope this helps and road ready soon
Old Oct 29, 2012 | 10:04 PM
Engine: LT-1
I got plenty of vacuum it gave me a hickey. I have come to get a new booster. I am removing it because it just their looking pretty. only line is coming from gas tank. i converted to edelbrock carb so their is no connection for this at least i dont think their is :O
9192camaro
16
Feb 3, 2019 12:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
milk
Aug 10, 2015 06:26 PM
z28addict8490
Aug 7, 2015 08:48 PM
