Don't laugh at me. . .what type of head-gasket?
Old Oct 28, 2012 | 06:24 PM
leon-lee's Avatar
Car: 88 camaro
Engine: 2.8L
Transmission: Automatic.
Not sure what type of head gasket I have. I ordered them for my son, but I'm not sure if I have a steel headgasket or what. How can I tell? If it helps any, I ordered them along with a rebuild kit, everything was ordered stock.
Old Oct 28, 2012 | 06:52 PM
Re: Don't laugh at me. . .what type of head-gasket?
Brand & part #?
Steel ones look like a thin sheet of .... steel. Composition ones look like some other material, with metal "fire ring" reinforcements around the cylinders.
Old Oct 28, 2012 | 07:56 PM
leon-lee's Avatar
Car: 88 camaro
Engine: 2.8L
Brand & part #?
Not sure, I'll dig the box out tomorrow and let you know. The way you described it I think its composition. It feels metallic, but there are metal reinforcements around the piston holes.
Old Nov 3, 2012 | 05:19 PM
leon-lee's Avatar
Car: 88 camaro
Engine: 2.8L
It's a victore reinz head gasket set. There was on individual part number for the gaskets. I'm really not sure what type of gasket it is, I don't think its steel because its semi-flexible and doesn't feel like steel. What I really need to know, if whether or not I need to use sealant on it when I put the heads on.
Old Nov 3, 2012 | 05:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i have only seen composition head gaskets on 2.8s-no sealant needed.
Old Nov 3, 2012 | 10:22 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
ive never seen a headgasket that you use any sort of silicone or rtv on, if that's what you're asking.
You will however need to use thread sealant on the head bolts.
colton_carlson
Mar 8, 2019 12:21 PM
dyeager535
Aug 28, 2015 08:10 AM
bdads
Aug 24, 2015 06:01 PM
CORV3TT3
Aug 23, 2015 11:26 AM
