Backfire and Misfire Problems
Old Oct 28, 2012 | 06:28 PM
dentalfloss1's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 V8 TBI
Transmission: Automatic
I have a 1989 Firebird Fomula 305 TBI. This past spring I replaced my spark plugs and at one point it started misfiring and backfiring. I replaced one plug wire and it worked fine. I later decided to replace all my plug wires with some I bought at Autozone. Which turned up to be the wrong size (7mm instead of 8). With these wrong sized wires I noticed it misfire and backfire again. Loose spark plug, I tightened it and immediately the ICM goes (turned over no start). Unsure of the cause at first, I replace the coil, pickup coil, and ICM. Finally it starts again, still misfires and backfires. I replace wrong sized plug wires with correct size ACCELL plug wires. still misfires and backfires. I just replaced cap and rotor and checked timing. still misfires and backfires.
tl;dr Car misfires and backfires, replaced almost all ignition components.
Old Oct 29, 2012 | 09:33 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: Backfire and Misfire Problems
7mm vs 8mm should have no effect. 7mm insulation should be plenty thick. Are you sure that all of your plug wires are correct? 1 8 4 3 6 5 7 2 in a clockwise formation?
Old Oct 30, 2012 | 03:37 PM
Engine: 305 V8 TBI
Yes, the firing order is correct. The misfire is rather slight, it seems to come and go every second or so. This morning it was quite cold and my engine ran great for about 10 mins and then it was back to the backfire and misfire. I would think that would mean a plug wire is touching something hot or metal? I have made several attempts at routing them correctly.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
