PROM AYBA?
Car: 86 trans am gta,and 88 corvette
Engine: TA-355ci tpi,vette 383 tpi
Transmission: 5spd manual,700r4
Axle/Gears: borgwarner 370 posi,vette is stock
PROM AYBA?
DOES ANYONE KNOW WERE TO FIND THE PROM BIN AYBA? IVE LOOKED EVERY WERE FOR IT.ANY LINKS OR INFO WOULD BE APPRECIATED.THANX
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: PROM AYBA?
i stand corrected .abya it is ,the memcal cross referance shows only that bcc will work with the resistor pac's .i have a rich condition with the bcc im useing and im trying to pass emmisions test.im not real experianced with the tables in the modifying process with tunerpro rt.i can burn them and they work but my tuning skills are less than a year old .any suggestions? thanx
Engine: Lb9
Transmission: M20
Re: PROM AYBA?
any $32, $32B or $6e will work with a 86-89 tpi netress and i/o buffer although the 89 lhm was improved.
