tpi sending assembly
Old Nov 4, 2012 | 01:37 PM
art91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 350 5.7 liter
I have a 1991 z28 with the TPI 350 5.7 liter engine. I pulled the fuel sending unit to replace the fuel pump and noticed that the small thing that looks like a thimble is cracked and busted. I need to know if it can be replaced or if anyone has one or if the whole assembly has to be replaced just for this part. It has a spring with a small plastic body inside, I believe it is some tyoe of vacuum. Below is a pic of it off & sitting (not mounted) on the hanger. I need this piece if anyone has one or know where I can get it. I cant put it back together knowing this part is badly damaged. Any help or info is greatly appreciated, Thanks for your time
Attached Thumbnails tpi sending assembly-tpi-sending.jpg   tpi sending assembly-tpi-sending-5.jpg
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
Sanjay
Aug 12, 2015 03:41 PM
