New symptoms to problem
Old Nov 5, 2012 | 06:13 PM
perschken's Avatar
Car: 91 Firebir Formula
Hi all,
Have a 91 350 tpi. it shudders when it has no load ie: nuetral, rev, or light throttle cruising, but still hickups when parked in gear. When I step on it or put in under load it runs perfect and has tons of power.
Recently it started a new trick, it dies when I put into gear from park sometimes. I have replaced and checked lots of stuff, ranging from ICM to plugs, wires, cap rotor, injectors, good fuel pressure etc. I have no service enging light.
Any ideas are appreciated.
Old Nov 5, 2012 | 06:39 PM
Damon's Avatar
Re: New symptoms to problem
Not much to go on, but I'm guessing a significant vacuum leak. Vacuum leaks cause the most havoc when manifold vacuum is high (idling, light load).
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
