327 small block
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 1984 Trans Am
Re: 327 small block
Just curious, but you're doing this instead of a 350....why?
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: 327 small block
327's and 350;s are both great. different behaviours for both engine. the long debate has been just that long ago and very long. so let the PO do what he pleases and lets keep this on track.
as for his original question go on summit start selecting all your engines info and viola!
Re: 327 small block
327's and 350;s ... different behaviours
They're EXACTLY THE SAME THING; one is just less of it than the other.
Both perfectly good motors; one is just .... more.
The other costs the same (more actually), but you get less. Kinda like.... you can go to the gas station, and you can whup out your $3.49.9 or whatever, and get a gallon of gas; but instead, if you're THAT kind of guy, then instead of a gallon, you can get only 3½ quarts if you want to. Yeah, they'll let you do that.
You get 327 parts the same places you get any other car parts. Auto parts stores.
Guest
Posts: n/a
Re: 327 small block
Car: 1984 Trans Am
Re: 327 small block
Bingo. I guarantee you he's putting in a 327 because he, like every other fan boy, believes the magical motor fairies come out of hiding whenever a 327 is around and sprinkle their mystical go fast motor fairy dust on it, making sure to fill every nook and cranny especially that vintage carburetor that is no doubt mounted square on top of the thing, after which all you need are happy thoughts to put the power to the ground and unleash all of that fire breathing, soul taking, dragon roaring block's power.
If he's already got a 327 block prepped and ready to go, then 327 it is. Cheaper to build that then finda 350 and prep it.
Maybe he does have his head filled with dreams of a 327 awsomeness. That's cool too. I just wanted to make sure that he thought it all through before he did it, if the block isn't already done/prepped because in all cases, a 350 is the better option.
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: 327 small block
i have everything ready to go except putting it all back together ,now i am not trying to be an ******* ,but this i what i want to put in my car all can put whatever in you cars ,now all i have now is a 2.8 v6 ,i dont want a hot rod to drink gas like crazy ,what i am building is something that looks and runs good and 'am putting alot of mney in it to i want it to be a show car it going to look like it just came off the show room floor ,and the 327 will give me alot more power than that of the 2.8i am building it to please me not no one else.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 327 small block
hope you're not expecting 37 MPG because that 327 will drink just as much as a 350 will. I see what you're doing though, and that's fine... just be realistic about it. Ultimately, we could ask the same question of "why did you go with a 350 when there are 400's" and then "why did you go with a smallblock with you couldve gone with a BBC or LS1".
The list goes on, and on.. heh. Just do it properly and you'll be happy with your results.
Guest
Posts: n/a
Re: 327 small block
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: 327 small block
You are aware a less powerful smaller motor in a comparable car as a bigger more powerful motor won't have to downshift half as much and your tiny difference in fuel economy is pretty much nullified. (Not to mention you can run taller gears in a bigger motor/more powerful and still be just as fast with more top end and get way better fuel mileage).
I have this argument with the guys at work all the time. They say a 350 is a truck motor and all love the 327's cause they grew up with them.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: 327 small block
My point was - why does anyone pick anything they do? I could've had a 496 or a 502 BBC in my car by now, but I opted for a 350 instead. I chose a 350 because that's what I wanted. One of these days, I'll probably try something different. I'm sure his case is no exception.
Car: 1984 Trans Am
Re: 327 small block
Just build it right, don't scimp on parts. The old Vette 327's put out as much HP as the 350's of the day so its obvious it can be done.
Besides, for any of you paying attention, Just what is the new Vortec 5.3L that they're putting in Trucks? Yeah...a 325! haha So there. They're still putting 327's in trucks!
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 327 small block
In a real world situation you usually make a little more power with more cubic inches but it's not going to be anywhere near the 50-100hp people like to imagine. Consider the 305 TPI and the 350 TPI. They have very similar heads (but the L98 083 heads have bigger valves and are a little better), the same cam and the same intake. In 92 the G92 (these got the L98 cam) LB9 305 makes 230hp and the 350 makes 245. This is with larger valves in the 350, but you can see the power difference really is VERY small.
But as a general rule of thumb, airflow cfm from your heads will dictate your power potential, and the camshaft choice will facilitate it. Displacement just dictates the torque curve.
An F1 2.4 liter v8 makes less torque than an L98, but it makes nearly 4 times the horsepower. Horsepower is, simplified, torque times RPM. Horsepower is how fast you can spin the torque. A smaller displacement engine makes less torque, but if the top end flows the same amount of air as it does on the larger engine, the smaller engine is able to spin faster. It makes up for the torque decrease with an RPM increase. This is the 327 "high revving" myth, but the same applies to 305's. The reason it's hard to make a 305 fast, is because you hit an RPM wall with stock internals, and you hit a cost wall with aftermarket parts to handle those RPMs that makes it a lot easier to just build a 383 or a 350. That's ignoring the practicality of having a high revving, high strung, low reliability, poor low RPM torque engine in a street car. THAT is the reason people build larger engines.
Think about it, when you put the same parts on a 383, the 383 taxes the airflow system much harder, and it will make a certain amount of torque, but it will exhaust the abilities of the head/cam combo to flow enough air at a lower RPM. What you do then is you actually just throw a bigger cam in it. The bigger cam will shift up the RPM range. The great key is how big can you make the cam before it's awful to drive on the street, and how big can you make the cam before the heads wont flow any more?
The reason people discourage 302's and 327's is because to get the same power as a high performance 350 (or 383), you have to put a bigger cam in it, spin it faster to higher RPM's, and in the process you lose low end torque, gas mileage, long term reliability, and you have to then change your stall in your trans, your gear ratios, etc. It quickly makes the car a huge pain in the butt to drive around every day and the car just becomes a garage kept drag car that only goes as fast as daily diver 383 cars.
So, in short, power is determined by airflow, where in the RPM range you make that power is determined by your displacement and your camshaft selection. To make more power you either upgrade the cylinder heads, or upgrade the cam to spin it faster.
You shouldnt be re-using the pistons and rods. Modern rods and pistons are far superior than that 40 year old stuff. You also shouldn't really bother trying to use the double humps, they were okay for the time, but even stock IROC heads make more power than camelhumps. They're worth more to a collector than they are to a racer.
There's nothing wrong with a 327, especially if its a showcar. It will get a little more attention that way and if you're not trying to race people or make a high horsepower daily driver it will be great.
Car: 1984 Trans Am
Re: 327 small block
Those are Gen III adn Gen IV engines that have a MUCH more efficient cylinder head design. Those 5.3's make 300hp stock, whereas an L98 makes 245 stock. The 5.3's with a camshaft can easily hit 350, wit ha little work nearly 400hp on all stock parts in the bottom end. Because the heads flow so much better than any factory Gen I head, they can hit those power levels at reasonable RPM's, on factory stock parts even. It truly is an apples to oranges comparison. And a 325 isnt a 327. And there isnt a single part on those engines that will fit on a 327. It's just a good example of how you can overcome a displacement defecit with more cylinder head airflow, but that's primarily due to excellent design. They probably make 100hp more, stock, than camelhumps on a cammed 350.
Nope. A 327 block and a 350 block are exactly the same. You can destroke that 327 and make a 302, or stroke it and make a 383. Ironic that from a cost perspective, the most expensive is the 302, the next most is the 327, and then cheapest is a 350. The 383 is probably cheaper than the 327 too. The only exception is if he is re-using the 327's crankshaft (About the only thing on a 327 worth keeping, and then only barely), but I'd just sell that and use the money to buy a 383 crankshaft.
You kind of hit on what I was getting at, butyou explained it. My Avalanche has a 5.3L motor in it. I don't know if it's the LS style, but it has Vortec heads on it which makes me think it's not an LS motor. Because of modern efficiency, they are able to put that motor in there instead of a 350/5.7L.
In so far as "if he's got it built', I meant if he's already got all the parts for it. I know a 327 uses the same block as the 350, I was simply meaning if he's already "ready" with all the parts for the 327. No need to waste money and go out and "re-buy" everything just to make it a 350.
Car: 1992 Camaro RS
Re: 327 small block
Guest
Posts: n/a
Re: 327 small block
:P That fits my top two reasons for doing the 327. It's ready to go and it's what you want to do!
Guest
Posts: n/a
Re: 327 small block
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: 327 small block
Wow the amount of hate here is surprising..
So what if he wants to build a 327? I love out of the ordinary swaps and I've considered it for a long time. The motor holds no "magic" just because it's a 327, however it's an unusual swap into a thirdgen and it's got a special quality just because of that! I've been considering building a 302 for my next thirdgen, wonder what kind of hate i'd get for that
If you want a 327 go for it man. It's obvious it doesn't have the power potential of a larger motor but that doesn't mean you can't build it to have enough to be fun.
Summit sells rebuild kits from a lot of manufacturers. What exactly were you looking to do with the engine? Daily driver, weekend warrior? What power level? I can help you find a kit.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: 327 small block
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: 327 small block
no its hate, the amount of rudeness in this site lately if someone doesnt go with a 350 is phenominal, why handicap yourself is sorta a dick comment because theres even better than a 350. some people have a want, its their car their budget instead of everyone being a dick about it let him do what he wants, and why dont we be supportive so he can do it right, so we dont have yet another hacked up thirdgen. After all isnt that what this site is for? or at least its what i thought it was, the preservation of thirdgens and building a community, and alot of people, Even I, have strayed from that, and overall as one big picture it gets to be ugly.
Anyways back to topic, Seems like the guys purpose for the car is a solid cruiser, nothing more, he wants to be happy with what he has and have a little nostalgia so to say. I think if he wants a 327 then let him, theres absolutely nothing wrong with them.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: 327 small block
A 400 will cost more money on an initial purchase to possibly suffer from core shift and will cost more (3-4x easily) to retrofit than a roller block 350.
With that aside, hypothetically let's say you find a 327 and a roller 350 for the same price. Which would you choose?
Now go buy your 327 and spend $400+ on a set of retrofit lifters. I'll go buy that roller 350 and spend $130 on a set of GMP LS7 lifters and still have 23CI over you for a cheaper amount of money.
EDIT:
Ultimately it is his car to do as he pleases but if someone told me they put a 327 in their car it holds about as much credential as someone putting a 305 in their car. Why spend the same amount, if not more money to have less?
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: 327 small block
my buddy's dad had a 327 with double hump heads an a cam an 4 barrel in his 64 impala ss with a muncie 4 speed .that thing made that ****ing sled haul *** . i tried to by the motor after his dad died an they would rather let it set an rot in the weeds then sell it . but back on topic ...
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: 327 small block
people come on now i posted one simple question and now all this ,i dont matter what he or she wants what matters is what i wanted ,if i wanted a 350 ,383 ,400 thats what i would have gotten but i got a 327 to go in my 1986 camaro ,yall can go a put whatever you want in your car ,and i will putmy 327 in my car
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
Re: 327 small block
I would try to find a local speedshop or engine builder to get the parts. You might pay a little more, but no shipping costs and you can get immediate feedback to questions you might have. It all depends on how much you are planning on buying. If one part, go online. If a series (maybe heads, cam, rockers, lifters, etc), I would go local.
Re: 327 small block
you tell them chevyman, I'm sure they all have valid points, but I took a perfectly good 350 out of my 63, and spent a year and a half finding all the rite date coded parts to put an origenal 300 hp 327 in it It was pretty expensive, but thats what I wanted. now I'm a happy camper.
Re: 327 small block
All of that "63" stuff is all fine and dandy, but doesn't apply here.
OP, if you're having to buy a "total rebuild kit" for a 327 and it needs to include a crank, it will likely cost MORE THAN the EXACT SAME THING except with a 3.48" crank instead of a 3.25" one. (assuming it's a large-journal 327) If it's a small-journal 327, the "total rebuild kit" for it will cost MORE THAN a junk buildable 350 core plus a "kit" for that.
In other words, in NO POSSIBLE UNIVERSE will you spend less on this 327, than on a 350. Has NOTHING to do with a 350 being "better" (or not) than a 327, and EVERYTHING to do with THE PRICE.
You will find the gas mileage to be close enough to identical that you wouldn't be able to measure the difference. A one-jet-size mistake in your carb tuning will make more difference than neutering your motor by 23 CID.
Big picture, building a 327 is just not "A Good Idea" in this day and time, for ANY reason, when you have to buy all the parts. Now if you already had pistons and a crank laying there, then yeah of course, do it; but since you don't, and you have to buy SOMETHING, concentrate on how to spend the LEAST and get the MOST (I can't understand how anyone WOULDN'T want that!), and you'll find out REAL QUICK that a "free" junk 327 ISN'T the path to that goal.
Re: 327 small block
I don't hate anything.It is a fact/law of physics smaller c.i. engines have to have a power curve in the upper rpm range no matter what you do to them.
I do have fond memories of building engines back then of engines from the 265's through the 327's.
Re: 327 small block
the best place to buy a rebuild kit
Parts stores, Summit / Jeg's, speed shop, etc. etc. etc.
There's no one "best" place, as in, all the others might as well shut their doors and go out of business. "Best" is some combination of price, availability (stocking), service, shipping cost, the specific parts included in the "kit", helpful sales staff, etc. He's just going to have to pick up the phone or mouse and do a tiny bit of strenuous exertion, sorry, we can't spoon-feed him EVERYTHING.
Same places as any other size of motor.
Which doesn't erase the fact that he'll end up spending MORE and getting LESS than he would if he put "327" out of his mind and attacked the problem in the LOGICAL fashion, as we keep trying to tell him before we got a bunch of irrelevant "numbers matching 63" crap, that isn't the least bit connected to what he's doing except by the tiny co-inkydinky that the CID happens to be the same, thrown in.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: 327 small block
Nobody is hating on him or his idea of a 327. But why in the world would you want to spend more money to have less motor/power?
Honestly, Sofa makes very valid points. He is also very knowledgeable. With the exception of a few others on here the rest of the community is the blind leading the blind with minimal experience.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: 327 small block
Just remember that once the money is spent - it's gone. If I was in the pursuit for more power for cheap (focusing on budget), I wouldn't be using a 327 setup. 383 strokers can be had for dirt cheap these days.
It's your ride though, like you said. Just do things the right way so you don't run into problems.
Car: 1992 Camaro RS
Re: 327 small block
The guy knows the advantages and disadvantages by now. If he wants to build the 327, let him build it.
New2Chevy
Sep 28, 2015 12:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
