92 firebird fuel pump wiring help needed!
Old Nov 16, 2012 | 09:51 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
i need to kick my fuel pump either via switch on the dash or by the key on position. but how can i accomplish that?
originally a TBI car.. where is the easiest place to provide power to the pump?
Old Nov 20, 2012 | 02:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At the fuel pump relay.
Old Nov 20, 2012 | 03:07 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Re: 92 firebird fuel pump wiring help needed!
factory fuel pump relay is long gone
Old Nov 20, 2012 | 03:18 PM
five7kid's Avatar
How about the wiring harness? Is it still there?
I started with a factory carb'd car with no in-tank pump, ran a wire to a relay that was connected to switched power. I have the PCM running mine, but all you would need to do is add switched power to one side of the relay coil circuit, and the other side to a switch going to ground. If you do it that way, the pump can't turn on unless the ignition is on.
Run a fuse, of course.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
