'88 350TPI intake off to fix leak, what now?
Old Nov 16, 2012 | 12:17 PM
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
I yarded my intake manifold and plenum assembly off a few days ago and while cleaning things up I have been contemplating what I can get away with. Thinking about a more aggressive cam and new lifters, valve job and hot tank on the heads, headers, and new distributor. there are a few things that trouble me though with my limited understanding of all the computer systems on the car.
1. Will the computer be able to account for a hotter cam or will it require modifications?
2. does anyone know if the flowtech's headers (BIG-11102FLT) have the O2 bungs in them or if I will have to drill and weld some in. also planning on buying the matching Y-pipe (BIG-11102YFLT)
3. What are te details on the stock distributor on the car so I can start searching out a reasonably price replacement.
Any help would be appreciated.
Old Nov 16, 2012 | 04:42 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: '88 350TPI intake off to fix leak, what now?
1 No. You'll need a tune
2 Already there
3 Divorced coil, small cap, computer controlled
Old Nov 17, 2012 | 08:14 PM
Rice01's Avatar
Engine: 383ci SBC
Thanks, its too bad about the cam. I'm still getting used to having a computer tell me no as far as modifications. Are the tunes reasonable, like a chip from summit for 80 bucks or a custom shop and a few hundo?
Old Nov 17, 2012 | 08:27 PM
Rice01's Avatar
Engine: 383ci SBC
And any suggestions on distributors?
Old Nov 17, 2012 | 10:06 PM
watajob's Avatar
Car: 92 T/A 'vert
I like my MSD:
http://www.summitracing.com/parts/ms...make/chevrolet
Forget the off the shelf chips. It cost me $500 for a half day w/5 dyno pulls to get it dialed in.
Old Nov 17, 2012 | 10:25 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
What's wrong with the stock one?
It may not be "cool" but it'll support a pretty healthy engine, afaik.
Old Nov 18, 2012 | 02:18 AM
Rice01's Avatar
Engine: 383ci SBC
The only reason to replace it is a good amount of what looks like rust dust or shavings collecting around the base. I found it when I went to change my ap and rotor.
86White_T/A305
Aug 17, 2015 12:16 AM
jackhammer
Aug 15, 2015 10:04 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
cstrobel65
Aug 15, 2015 10:19 AM
