Code 33&36 help
Old Nov 20, 2012 | 01:51 AM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Code 33&36 help
I changed my MAF after these codes flashed, ran it for 10 min and it still runs like crap, kinda sounds like the catalytic converter is clogged. Could running the car this way mess up the cats? What other reasons besides MAF could flash 33&36 codes. I have a 88 iroc camaro 350 tpi, I've got the heads rebuilt recently, and it ran find until I took a 2hr trip and that's when code 36 flashed, when I drove back home and turned car off to unload stuff and turned it back on it sounded like a lifter got stuck, then gradualitly got lower but didn't go away till the next morning. I NEED HELP WITH THIS ISSUE, THIS IS THE ONLY CAR I HAVE NOW SINCE MY BRONCO BROKE DOWN. MY WIFE USUALY DRIVES THE CAMARO AND I THE BRONCO. ANY HELP WILL BE APPRECIATED. THANKS IN ADVANCE.
Old Nov 20, 2012 | 05:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Code 33&36 help
Originally Posted by saldav420
I changed my MAF
A code only indicates a problem with a system ;not that the item in that system is actually faulty
Could be wiring or grounds also
In your case you have the MAF burnoff relay code
Fault find here
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_36.htm
Old Nov 20, 2012 | 07:25 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: Code 33&36 help
subscribed
Old Nov 20, 2012 | 07:28 AM
saldav420's Avatar
Transmission: 700r
Re: Code 33&36 help
Subscribed? What do you mean?
Old Nov 20, 2012 | 07:48 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Code 33&36 help
He's just posting in the thread so that he will receive e-mail updates when somebody posts something.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
