Smoking and gas issues?
Old Nov 23, 2012 | 10:06 AM
TA<3er4Life's Avatar
Hello, first I would like ot thank everyone here ont he forums who have been helping me out with my car. It is back running now, how ever I am still having problems with it. When I start the car a big plume of blue smoke shoots out the back along with a rough idle. The car will idle normal after about 5 minutes, the smoke however continues. The smoke is blueish in tint, and smells like fuel and oil. Which brings me to my next point, the car is also using a lot of fuel. Its using more than normal, and when is low on fuel does not want to run good. It bogs and dies on me. Just recently replaced the fuel pressure regulator, and prior to that the engine was flooded with fuel. Dont know if that helps, but what should I be checking for?
Old Nov 23, 2012 | 10:11 AM
Re: Smoking and gas issues?
What induction system?
Old Nov 23, 2012 | 10:14 AM
Its a 1987 trans am 305 TPI. If thats what you were asking for.
Old Nov 23, 2012 | 11:32 AM
Yup, that would be it...
Sounds like you have at least one leaking injector. Dumps all the fuel into the intake while not running.
You can take em out, plug em into the fuel rail with the little clippy things so they don't pop out, hook it all back up to the fuel lines but not the electric plugs, turn the key On a couple of times to prime it, and see which one(s) drip(s). Watch the FPR fitting as well and see if fuel drips out of it, just in case your new one is bad.
Old Nov 23, 2012 | 04:34 PM
Alright thank you so much! I will do this asap.
Old Nov 24, 2012 | 07:17 PM
Ive tried to get to the injectors but could not figure out how to get the entire rail off. After putting it all back together the car now runs even worse, when I give it gas in drive it just bogs down and loses power, however in park it does just fine with the engine taking throttle. What could have possibly went wrong?
Old Nov 25, 2012 | 06:43 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm sure you saw the 4 bolts that hold the fuel rail down. Just lift it stright up. On an 87, there is another cold start injector (near injector #5) that you will have to remove in order to lift the rail. You'll have to temporarily reconnect it to the rail to test if the injectors are leaking.
Old Nov 28, 2012 | 02:26 PM
I am still confused on how to remove the fuel rail, I have removed the 4 bolts but the thing isnt budging?
Old Nov 28, 2012 | 08:57 PM
All there is to it.
Old Dec 3, 2012 | 03:37 PM
Ive pulled both runners, and the rail still is barely moving, I am lifting on it with more than I know is necessary force and it just wont lift. What could be possibly holding it on? Can someone tell me everything that should be disconnected and the bolt locations?
bryan623
Mar 22, 2021 06:43 PM
chazman
Aug 28, 2018 03:25 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
