What Rollers will Fit?
Old Nov 23, 2012 | 02:47 PM
bmcclain's Avatar
Car: 87 iroc
Transmission: t5
I've got a stock 87 iroc, 305 that I'm changing out valve guide seals on. I've decided while I'm in there to replace the stock rockers with some rollers.
I need some direction on which ones will fit under the stock covers with no modifications. I've already checked mine and they are not self aligning type.
I would rather here from the guys who have done this and what they have used, rather than the guy that has put a set on a '72 big block.
Old Nov 23, 2012 | 03:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: What Rollers will Fit?
I have considered this but haven't done it because I don't think there's much to gain; maybe less guide wear?
Anyway, I wouldn't go anything more exotic than Comp Cams Magnum Rocker kit RPH300. These are for '87 and later and should clear the centerbolt rocker covers and they're non-self aligning.
http://www.compcams.com/catalog/COMP...g_2012_325.pdf
http://www.summitracing.com/parts/cc...0/applications
Post up which rockers you settle on and post some install pics when you're finished.
Old Nov 23, 2012 | 08:26 PM
bmcclain's Avatar
Car: 87 iroc
Transmission: t5
thanks paulo.
I thought about those, but I'm wanting full roller (with fulcrum bearings) not just roller tip, but I might be limited to using these.
Any other input on this anyone?
Old Nov 23, 2012 | 11:41 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
No full roller rocker will fit under a bone stock valve cover... even most aftermarket center bolt valve covers will need some modification.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
blackroc68
Sep 1, 2015 08:01 PM
gixxer92
Sep 1, 2015 04:32 PM
