Were small-cap HEI distributors used only on roller engines?
Old Nov 28, 2012 | 11:53 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I have an LT4 hot cam with a carb and large cap HEI distributor. I need to replace the distributor gear with a melonized one. I have a spare small-cap HEI but I don't know what it came out of. Is it safe to assume it came out of a roller cam engine and I can rob the distributor gear out of it for my large cap distributor? I have to measure the shaft diameters yet but from what I've read I think I'll need to bore the gear up to .491" from .428".
Old Nov 28, 2012 | 11:58 AM
Jeffs82TA's Avatar
Re: Were small-cap HEI distributors used only on roller engines?
Originally Posted by Ukraine Train
I have an LT4 hot cam with a carb and large cap HEI distributor. I need to replace the distributor gear with a melonized one. I have a spare small-cap HEI but I don't know what it came out of. Is it safe to assume it came out of a roller cam engine and I can rob the distributor gear out of it for my large cap distributor? I have to measure the shaft diameters yet but from what I've read I think I'll need to bore the gear up to .491" from .420" or so.
Vettes never switched to small cap, just get one from one of those.
Old Nov 28, 2012 | 02:22 PM
Damon's Avatar
Or you could just leave the stock flat tappet cam gear on your existing HEI and just stab that puppy in. They work just fine on factory roller cams. Done it too many times to remember them all.
Old Nov 28, 2012 | 03:28 PM
Car: '87 Camaro LT
Engine: 355 L98
I ran the stock gear for a while before I learned that you're supposed to match it to the cam material and I can see excessive wear on it. I'd rather do it right, especially since I already have a gear to use. There's a machine shop at work that will bore it for me.
Old Nov 29, 2012 | 07:36 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
LT4 hotcam does not require a special distributor gear. Like previously said, the factory roller cams come with a melonized distributor gear on the cam.
Aftermarket billet cams require a different gear.
Old Nov 29, 2012 | 07:45 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
.491 gear
http://www.summitracing.com/parts/ac...6413/overview/
.428 gear
http://www.summitracing.com/parts/nal-19052845
Both melonized
Old Nov 29, 2012 | 10:20 AM
Car: '87 Camaro LT
Engine: 355 L98
But this cam was originally designed for factory roller engines that already had a melonized distributor/oil pump drive gear, right? So if I have a cast iron gear on my old big cap HEI distributor, why wouldn't I need to change it to a melonized gear?
Old Nov 29, 2012 | 03:30 PM
3rdgenmaro's Avatar
Car: 88 IROC
I read your previous posts alittle too quick.
I do not know about the cast gears.
So when are you getting it bored? Hope it all works out for you.
Old Nov 29, 2012 | 05:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Many trucks used the small cap HEI/CC distributors and still had a flat tappet cam. If the distributor is from a f-body, then it is a roller cam distributor. IIRC, the small cap distributors started in '88 in f-body's with the TBI engines.
RBob.
Old Nov 29, 2012 | 07:31 PM
Car: '87 Camaro LT
Engine: 355 L98
That's good to know about truck engines. I suppose I can take the easy way out and just buy a new gear. Or maybe I can get the QC lab at work to check the hardness and compare it to cast iron. There should be an obvious difference.
Old Nov 30, 2012 | 02:10 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i put about 20,000 miles over a period of 4 years on the 355 that was in my 71 Nova with the HOT cam and whatever random mid 70's HEI distributor i had laying around when i put it together, and i never saw any evidence of any sort of wear on the gears or felt any play in the dozens of times i had the distributor out for various reasons.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
midias
Aug 15, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
