What does this sound like?
Old Dec 5, 2012 | 03:57 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I have an '85 Corvette which has the newer 165 ecm in it. I am just getting it running again after an intake change. When I start it, sometimes it will smoke black and the idle is hunting all over the place along with it being unable to rev like it should. If I unplug the maf the idle drops but it will then idle within a 10-20 rpm spread and will rev like it should. Does this sound like a bad maf to you? I accidentally dropped the maf when the engine was apart so I'm thinking that's what happened to it.
Old Dec 5, 2012 | 04:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What does this sound like?
kinda sounds like the maf butter fingers ! Are you getting and maf codes ?
Old Dec 5, 2012 | 06:30 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
HAhaha, I called myself a lot worse than butterfingers. Yes it threw a code 33 but I was disconnecting it while it was running so I thought that was the reason. Upon further testing today I found I have no ground to the maf so I'm going to have to double check my wiring on the relays tomorrow
Old Dec 5, 2012 | 06:38 PM
Engine: Lb9
Transmission: M20
The black/ white on pin A of the maf is the maf ground it goes to d1 of your 165 .
Old Dec 5, 2012 | 06:50 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I know that wire is where it's supposed to be because I went over the re-pinning instructions today, I'm going to have to look at the relay wiring and check the black/white wire for continuity. I'm hoping it's a screwup done by me, I really don't want to shell out the bucks for another maf.
Old Dec 5, 2012 | 07:06 PM
Engine: Lb9
Transmission: M20
there are alot of guy parting out thirdgen here in the classifieds you might be able to pickup a known good bosh for $50-60.
Old Dec 5, 2012 | 07:11 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Once I get the wiring straight I'll know if I will need one or not. Curiosity has got to me, I'm heading back out to the garage now to see what I can dig up. Thanks for coming to my rescue again, I owe you.
Old Dec 5, 2012 | 07:12 PM
Engine: Lb9
Transmission: M20
I didn't do anything but will crack open a beer if that helps you lol
Old Dec 5, 2012 | 07:18 PM
Engine: Lb9
Transmission: M20
I think the code 33 can also be thrown if there is no signal back to the ecm b12 or I have seen it thrown with a mild cam during cruse if the threshold goes over 45gps programing can fix that.
Old Dec 5, 2012 | 08:40 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I can't believe what I just found. How can a person do the ecm re-pinning and not make a mistake but when it comes to wiring up 6 wires from the old burnoff connector to the new relays he can get it AFU.
I'm done for tonight, I'll re-wire it all tomorrow, thanks for cracking open that beer, it got me back on track,
Old Dec 5, 2012 | 08:41 PM
Engine: Lb9
Transmission: M20
moved onto wine for dinner waiting for you to go do your home work lol
Old Dec 6, 2012 | 07:42 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I have been in the garage all day tracing wires. I think they are all okay but now my maf connector is completely dead so I am wondering if I have a bad relay. Is there a procedure to check these? I have the fsm for my car but it is no good for this info. Also, should the big orange wire to the ecm be hot all the time, key off?
Old Dec 6, 2012 | 08:05 PM
Engine: Lb9
Transmission: M20
Old Dec 6, 2012 | 08:08 PM
Engine: Lb9
Transmission: M20
The top of the relay should show the schematic it does not matter if d and f is reversed in polarity.
Old Dec 6, 2012 | 08:17 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
What's on the top of the relay is probably part of the problem, it says Made in China. I'll try tomorrow using the diagram you posted.
Old Dec 6, 2012 | 08:29 PM
Engine: Lb9
Transmission: M20
I more fond of the newer style relays like acdelco 15-8240 pigtail, PT1115 gm/acdelco 4089936, 14103304 , 15-8240 they are heavy duty and have weather pack seals on them.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Dec 6, 2012 | 08:33 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I have the relays out of the car, is there a way to test them to see if they are good?
Old Dec 6, 2012 | 08:41 PM
Engine: Lb9
Transmission: M20
are they the older style ones on the left in this picture with no weather seal on them ?
Old Dec 6, 2012 | 08:43 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Yes
Old Dec 6, 2012 | 08:46 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...nces-they.html
Let me go see if I have any old ones to let you know what each post is.
Old Dec 6, 2012 | 08:56 PM
Engine: Lb9
Transmission: M20
I only have a old gm burn off one that the schematic is not shown, But I can give you the information another way.
Old Dec 6, 2012 | 08:58 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I'm all ears.
Old Dec 6, 2012 | 09:04 PM
Engine: Lb9
Transmission: M20
This is the mass power relay, The black/white wire and the tan /white control the relay the black/white is the ground if you get these reversed the relay will still work. you can see in the schematic it is always shown as a n/o circuit so when these 2 leads I mentioned above are not powered pin e and c are connected and when powered e and a connect.
Old Dec 6, 2012 | 09:10 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I'm about 99% sure all the wiring is okay but since the maf connector has no power to it I can only guess it is a relay, that is why I was wondering if there is a way to check the relay off the car. Such as putting power to one terminal and grounding another to see if it clicks or whatever.
Engine: Lb9
Transmission: M20
This is the burn off relay the orange(the one next to the blk) and black are the relay control wires .a and e are open apply power and ground to the orange and blk and a and e will connect and have continuity between these 2 terminals.
Old Dec 6, 2012 | 09:13 PM
Engine: Lb9
Transmission: M20
I hope all that jibberish makes sense
Old Dec 6, 2012 | 09:55 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Yes it does, now I know what I am going to be doing tomorrow.
Old Dec 6, 2012 | 10:05 PM
Engine: Lb9
Transmission: M20
going fishing
Old Dec 7, 2012 | 08:21 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Yep, fishing for what I screwed up while re-pinning the ecm. I'm hoping that is all it is. I remember when I was doing it I was comparing the wire colors in the fsm with what was on the car and there was a gray wire that was not supposed to be gray according to the fsm but I can't remember now what color that wire was supposed to be, the car has never had any wiring done to it it is all oem.
I'm starting from the beginning again today then see if I can spot the problem. I knew I should have found somebody to do this, I hate wiring.
Old Dec 7, 2012 | 08:31 AM
Engine: Lb9
Transmission: M20
There was a supplement for the electrical for the 85 f-body that came out shortly after the helm so maybe the same for the y-body. You can always print out this link and ohm out all the wires just cross them off the pictures after you test each one. Best of luck finding the wiring issue.
http://www.chevythunder.com/maf_sens...rcuits%202.JPG
Old Dec 7, 2012 | 08:38 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Following that diagram will be one of my activities today, testing for continuity. I'm thankful there weren't that many wires involved in the re-pinning. I'll probably be back tonight either happy as a pig in s**t or po'd to the max. Thanks for sticking with me. It's time.
Old Dec 7, 2012 | 09:30 AM
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
Thank you for the wiring diagram. I've got a code 33, and after replacing the burn-off relay and the MAF, I now see that there's ANOTHER relay I need to check. The wiring diagram I had made me think the orange/orange/dark blue/black was the cooling fan relay. The two MAF relays are beside the fuel pump relay, correct?? Drivers side of the engine compartment, in the corner under the hood hinge? (88 Firebird wiring harness, if it matters, L98 engine)
Old Dec 7, 2012 | 09:44 AM
Engine: Lb9
Transmission: M20
yes your in the right spot for the maf power and burn off relay's.
Old Dec 7, 2012 | 09:50 AM
Engine: Lb9
Transmission: M20
Old Dec 7, 2012 | 10:02 AM
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
Yeah, I followed through the flowchart, and got to "Check all related connectors for making good contact. If OK, MAF is faulty" but this is the second MAF to throw this. I'll have to dig a little deeper when I get home tonight, but the burn-off relay is still the old one (replaced the MAF power relay). I saw somewhere else to look for a vacuum leak under the intake (rubber elbow).
Old Dec 7, 2012 | 10:08 AM
Engine: Lb9
Transmission: M20
I'm not sure if you have read this post.
https://www.thirdgen.org/forums/tech...ible-code.html
Old Dec 7, 2012 | 10:33 AM
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
No, I hadn't seen it, but it makes sense... Why do I always get the really good info to try when I'm stuck at work!?
Old Dec 7, 2012 | 10:55 AM
Engine: Lb9
Transmission: M20
Time to go home sick and have a long weekend
Old Dec 7, 2012 | 10:57 AM
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
I would, but I'm the only tech in today. I do have a week off coming up. Really need to redo the top end gaskets on the engine (have them, just haven't found the time to do it), too.
Old Dec 7, 2012 | 11:59 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I think I found my problem, I have all the wires right now, (I hope). Your last line in your response is my only gray area now and I'm sure it has something to do with that beer you opened. You have e & c connected when not powered, then you have that when power is applied e&c connect, anyway on my power relay the e&c are connected no matter what power or not. I have a new one coming tomorrow morning so maybe this ordeal is coming to a close.
Ooops my mistake, I re read your response, I stand corrected
Old Dec 7, 2012 | 12:05 PM
Engine: Lb9
Transmission: M20
I was just going off the schematic It maybe incorrect but you can see the connection on the maf power relay on post #13 e and c are connected when powered the connection changes to a and e. It could have been the beer just sayn
Old Dec 7, 2012 | 12:10 PM
  #42
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
No, it was my mistake, I have been looking at wire numbers & colors so long my eyes are crossed. I misread where you covered two different wire positions, e&a and e&c. And I haven't even had a beer,,,maybe I better. At any rate, I am done until tomorrow morning.
Old Dec 7, 2012 | 04:33 PM
  #43
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
Just checked my MAF... just a bit over 22K across pins D & E. So, looks like a trip to the parts store with my multimeter...
Old Dec 16, 2012 | 07:21 PM
  #44
TechMav's Avatar
Car: 1986 Camaro
Engine: 350TPI
Finally got the parts store to give me the correct MAF. Had to get the one for an 85 Vette. Was seeing about 1.8V at idle on the one the parts store said was the 'correct' unit.
With the Vette MAF, I'm seeing about 260mV at idle on pin C (middle pin). Anyone else who is having trouble, check pin C (between C and ground), and see what your voltage is. If the ECM sees over 2.2V at anything less than 1/4 throttle, it'll set a Code 33. You should be seeing well under 0.5V.
Took it for a test drive, and once the computer relearned, everything is good. tunedperformanc, thank you for your help on this.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
