Clogged Injector?
Old Dec 5, 2012 | 08:38 PM
keester's Avatar
Clogged Injector?
I recently aquired an 87 GTA that is slowly being put back on the road after sitting for 5 years.
The #8 cylinder is not firing. I know there is spark. The injector has power and it checks with a meter. I assume it is clogged or some other mechanical problem. I put in some lucas injector cleaner but I have only run about 1 gallon of gas since dumping it in.
Here is the question. Should I run the rest of the tank of gas then see what happens or just go ahead and change the injector. Thanks
Old Dec 6, 2012 | 05:57 PM
88gtatony's Avatar
Car: 1988 gta, 1986 trans an
Engine: 305 tpi, 305 tpi
Transmission: 5 speed, auto
Axle/Gears: 3.45, 2.77
Re: Clogged Injector?
did you check the injectors with an ohm meter? unplug the connectors and test them.
i believe they should be around 16 ohms... im sure some one else will chime in...
Old Dec 7, 2012 | 01:04 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
If you do decide to change it, do all 8.
Old Dec 7, 2012 | 07:54 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Tap on the body of the injector with a wrench while the engine is running. You can tell when they start clicking.
Old Dec 7, 2012 | 03:47 PM
keester's Avatar
I had too get a new volt meter, 17.5
Old Dec 7, 2012 | 03:49 PM
keester's Avatar
That will be the plan. Found the web site on here for South bay injectors. Looks like great prices.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
