headlight issues!
Old Dec 10, 2012 | 11:52 AM
SPEEDSKATER's Avatar
Engine: sbc
headlight issues!
83 TA. Headlights won't pop up or go down. When I manually crank them up and turn on the lights, the pass side headlight motor closes it halfway down. I keep turning lights back on and it eventually closes it shut. The driver side doesn't do anything.
What is causing this problem and what can I do to fix it?
Old Dec 10, 2012 | 08:58 PM
Damon's Avatar
Re: headlight issues!
It is common for the gears in the headight motors to strip out..... but I suspect you already know that.
Are you saying they don't even TRY to open or close on their own?? Can you hear the motors turning when you turn the headlights off and on?
Paging electrical gurus! I think this is not the usual "mechanical" headlight issue.
Old Dec 11, 2012 | 08:22 AM
Engine: sbc
They don't even try to pop up. Can't hear the motor. But when up, when I turn the lights on, the pass. headlight tries to flip down.
Old Dec 11, 2012 | 12:33 PM
Damon's Avatar
You might want to post up in the Electrical section of the board. If you're not hearing the motors even try AND one of them is trying to close when it should be open I think you got a problem that is mostly electrical in nature, maybe entirely electrical in nature.
Old Dec 12, 2012 | 04:40 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Search the elec section, many threads about that . Yours is controlled by three relays under the hood, one or more or the switch is malfunctioning.
Old Dec 12, 2012 | 02:08 PM
Cordero51's Avatar
Car: 1985 pontiac firebird S/E
Engine: 5.0L 305 carb
Transmission: auto
I had something similar like this with my firebird it could actually be the headlight motor relay that's gone bad. When mine went bad the motor stayed up on the on position and was draining te cars battery. So for u the relay might have blown and is giving the cat mixed signals when u are hiring the switch.
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
