quench height? 0.060 too much?
Car: 1984 Z28
Engine: Vortec 350, hotcam
Right now I'm trying to get my compression/quench height about right. My potential set up would be a piston 0.045 in the hole and a 0.015 thick headgasket. That would put my quench at 0.060 but i've heard you want it at 0.040? Would that be okay or should I go lower?
Re: quench height? 0.060 too much?
That's so much, it's basically non-existent.
The effect also becomes less significant as compression decreases; and is altogether non-existent if the pistons hav a dish.
Probably not worth worrying about in your situation.
I'd also recommend against the shim gasket... a motor with slightly lower compression because of a thick gasket that seals, will make more power than one with shlightly higher compression but gaskets that leak, as those virtually always do, especially between the 2 center cylinders.
skinny z
Oct 5, 2015 06:23 PM
