Gas spitting out when filling
Old Dec 15, 2012 | 12:49 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
So after getting my gas tank changed over with a stock tank and new neck, if I try to fill it with gas full speed at the pump it stops and spits gas back out the spout. Do I just need to adjust the two openings above the spout?
Old Dec 15, 2012 | 12:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Gas spitting out when filling
If the tank can't vent very well fuel will come back up the fill spout.
Old Dec 15, 2012 | 02:03 PM
Car: 1984 Trans Am
Axle/Gears: Stock
How would I adjust that? Just the two openings on the filler tube?
Old Dec 15, 2012 | 02:16 PM
Engine: Lb9
Transmission: M20
I'm thinking the holes need to be larger you may have to pull the tank and install a barb an vent hose from the top of the tank to the top of the fill inlet
Old Dec 15, 2012 | 02:48 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
The tank should have vents, are the connected? Or are the capped?
Old Dec 15, 2012 | 04:25 PM
Engine: Lb9
Transmission: M20
I thought there is just a vent valve in conjunction with the ccp. So when the ccp solenoid opens it draws air through the vent valve and vapor out of the ccp canister into a ported passing in the tb ?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Apr 28, 2019 07:45 AM
corey8084
Sep 17, 2015 02:56 PM
Glowsock
Sep 11, 2015 11:09 PM
