should I be concerned??
Old Dec 21, 2012 | 03:18 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Thought I had this motor combo figured out, but maybe not.
64cc aluminum heads
5cc flat tops at -.002 deck height
.039 gasket
comp cam 08-501-8 IVC 35*??
5.7 motor
Looks like 10.4 static and over 9 dynamic
Can anyone suggest a diff cam or any comment?
Old Dec 21, 2012 | 03:43 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: should I be concerned??
Run a similar setup with iron vortecs. Setup works decent, but wish I went with more cam. Either the 502 or 503.
What intake are you using and what are your goals?
Old Dec 21, 2012 | 03:53 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Stock tpi with ported base. Looking for a good running street car. Picked a conservative cam to work with the low revving intake. The high dynamic # has me concerned about ping.
What's your beef with the 501?
Old Dec 21, 2012 | 04:09 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
The cam works really well and is great for the street. Now I am not sure if it is a limitation of the cam, my intake or heads, but I feel it falls flat very quickly and stops pulling by about 5k(yes I know that is tpi, but it does not rub me the right way). Going to some trial and error in the spring with a new intake setup.
I have been trying to tune my car as well, and keep getting knock. Think it is from an exhaust leak as well as it hitting the frame a touch, but now you have me thinking as well. Changing the exhaust this winter as well, so we will see if that cures it. I did notice that the more that I beat on the car, the less knock there is, but that could be anything as well.
Look at my sig for my mods.
Old Dec 21, 2012 | 04:13 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
What piston,quench, cr?
Old Dec 27, 2012 | 08:22 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
I am not 100% sure because the motor is basically stock with a cam only. The motor is a 98 vortec 350 from a pickup. Stock rebuild(head gaskets, flat top pistons with I believe valve relief and 64cc chambers). I think they are rated at 9.5:1 from GM, but I am sure the cam changed that a bit.
Old Dec 27, 2012 | 09:30 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Run 93 octane and dont overheat engine. Youll be fine.
Nighthawkf-117
Sep 24, 2015 02:47 PM
apie2546
Sep 24, 2015 12:27 AM
skip91
Sep 22, 2015 10:25 AM
anesthes
Sep 18, 2015 12:34 PM
corey8084
Sep 17, 2015 02:56 PM
