Vacuum tube for Distributor
Old Dec 26, 2012 | 08:31 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
As I now have my new dizzy and the previous one was a CC unit. What can I use for the vacuum tube? I also need to find a spot to connect it to (I might have the connection on the carby though).
Cheers.
Jonno.
Old Dec 26, 2012 | 10:25 AM
Re: Vacuum tube for Distributor
If you have the connection on the carb, try it.
Also try hooking it up straight to manifold vacuum.
See which you like better and run with it.
Old Dec 26, 2012 | 04:20 PM
djjon76's Avatar
Car: '84 Trans Am
Will do. What type of tubing is it though?
Is it just stuff similar to the washer nozzle stuff?
Old Dec 26, 2012 | 06:14 PM
Yup, pretty much.
You can use that plastic stuff, or rubber hose, or even metal tube like they used to in the 60s; doesn't make the slightest difference.
Old Dec 27, 2012 | 12:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Ask for vacuum hose at the parts store. If they give you a blank look, ask for windshield washer hose instead.
Old Dec 27, 2012 | 08:09 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
dj - Supercheap sells it by the metre or in 2M packs. Rubber hose, about 4mm would do iirc.
gta892000
Aug 11, 2019 11:16 AM
85 Jimmy
Sep 30, 2015 07:56 AM
86CamaroDan
Sep 29, 2015 10:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
