spring rate on motown 220s
Old Dec 26, 2012 | 08:19 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
im using these heads on a turbo build and am using a summit 224/224 cam. the factory springs are set up for dual springs and solid roller cams. they are way too stiff for what i need. the outer diameter of these springs are 1.550, will there be any problem with me using these springs for it?
http://www.summitracing.com/parts/sum-174000
Old Dec 26, 2012 | 08:37 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Re: spring rate on motown 220s
You will need new retainers and possibly locks. Your also going to have to take into account the centering shim when calculating spring height. Bill Mitchell sells the parts needed on his site. The springs I used were big block head valve springs. The 1.550 spring diameter seems to be common in bbs.
Old Dec 26, 2012 | 09:40 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
Sweet,thanks a ton
87v6Bird
Jul 1, 2018 04:12 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
sandman92084
Sep 12, 2015 10:27 PM
86IROC112
Sep 11, 2015 04:04 PM
