oil leak problem
Old Jan 1, 2013 | 11:35 PM
everzack's Avatar
oil leak problem
Hey everyone, I'm thinking about buying a 92 firebird v6 automatic, it starts great and sounds great the only problem is while it is running there is a massive oil leak coming from the oil pan. the current owner tells me it is either the oil filter or filter housing but my father doesn't think so. any ideas on what could cause this problem and whether it would be a major problem? thanks for the help.
Old Jan 1, 2013 | 11:56 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: oil leak problem
Simple-- Old rubber filter gasket still on the filter mount boss.
Valve cover gasket.
PITA-- Cracked // broken dipstick tube.
Oil pan // oil pan gasket.
Bad-- Cracked block // cracked filter mount boss.
Just a lil to think about. I'm sure there may be something more to look at.
Old Jan 2, 2013 | 12:02 AM
Car: '87 Camaro
PS-- Another thought--
Simple-- Oil pressure sender
What's your dads thoughts?
Old Jan 2, 2013 | 12:04 AM
everzack's Avatar
Thanks, I'll look into it a little more
Old Jan 2, 2013 | 12:05 AM
everzack's Avatar
he thinks it is a cracked blocked or will soon become one if is driven at all.
Old Jan 2, 2013 | 01:44 AM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
I had an oil leak on my l82 due to an oil passage bolt hole not plugged on the front passenger side. I'd double check that...
Infested
May 22, 2018 11:56 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
