broken oil pressure sending unit
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
so as i took out the engine i find this
would this render my block useless?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: broken oil pressure sending unit
very fixable-keeping repair debris out of the oil passage will be the hardest part.Could grind the upper part of the oil hole to a slightly larger diameter them tap some new threads further down to accept a longer pipe for the sender.To reduce chance of debris dropping in,could do the repair with engine upside down or possibly take a galley plug out under that passage and use a small magnet to attract away iron particles-don't have a spare block handy to examine right now to see if that would work well...
14010201
@8t2 z-chev ok yeah, that might work
@sofakingdum haha yeah i know, but im dealing with what i have, i dont feel like busting out 500$ at a junkyard for a 350
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
