G92 option
Old Jan 6, 2013 | 04:12 AM
Keith Yee's Avatar
G92 option
Quick question, in 1987, did the G92 option only available on a 305 motor instead of a 350?
Old Jan 6, 2013 | 06:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: G92 option
G92 (performance axle ratio) available only on IROC-Z with 5.0 TPI (LB9). G92 was available on IROC-Z convertible in 1987.
All 1987 350 TPI (B2L) IROC-Z's came standard with the 3.27 BW rear end
https://www.thirdgen.org/1987-chevy-camaro
Old Jan 6, 2013 | 10:43 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: G92 option
There is also a 1LE option,which is similar to the G92. My brother had it on his 91' 305 formula. Bigger brakes, 3:42 gears, big rotors, radio delete, N10 option dual ypipe etc,etc.
Old Jan 6, 2013 | 01:56 PM
Keith Yee's Avatar
Re: G92 option
thanks, I was just wondering. I have 87 5.7 L98 motor. I thought I had all the options available for that year on my car.
I was looking at the old Camaro Dealer order sheet and I thought there was a option that you can get the G92 package but its only available for a 305. That makes sense.
Old Jan 6, 2013 | 10:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: G92 option
Originally Posted by Keith Yee
there was a option that you can get the G92 package but its only available for a 305. .
As noted in the link I posted above
350 in '87 only had one axle ratio so G92 wasn't available
G92 isn't really a option as such , just a factory indicator that a optional " performance " axle has been installed
if one was available. The actual installed ratio has it's own RPO code,typically GXX
Some GM axle codes
GH0 : AXLE REAR, 3.54 RATIO
GH2 : AXLE REAR, 2.29 RATIO
GH3 : AXLE REAR, 2.77 RATIO
GH4 : AXLE REAR, 2.92 RATIO
GM1 : AXLE REAR, 2.59 RATIO
GM3 : AXLE REAR, 3.45 RATIO
GM8 : AXLE REAR, 2.56 RATIO
GN9 : AXLE REAR, 4.11 RATIO
GT7 : AXLE REAR, 3.33 RATIO
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
Old Jan 6, 2013 | 11:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: G92 option
https://www.thirdgen.org/forums/post...28-post47.html
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
