diagnose emission reading :s
Old Jan 11, 2013 | 07:39 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Need help translating read out
My 91 305 TBI failed emission test. all stock but for the cat-back exhaust, car runs fine but will puff blue on start up (has done this for sometime but has always passed)
HC
driving 117. =fail (88. max)
idle 247 =fail (82 max)
NOx
driving 603. =pass (953 max) ....higher than average but still a pass
CO
driving .11 =pass (.64 max)
idle .08 =pass (.50 max)
any ideas on where to start?
Old Jan 11, 2013 | 08:29 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: diagnose emission reading :s
Most likely unburned fuel. Check ign timing, spark plugs, thermostat.
Old Jan 11, 2013 | 08:55 PM
CTS first; then a cat.
Old Jan 11, 2013 | 08:58 PM
Any codes?
Old Jan 11, 2013 | 11:05 PM
sid rs91's Avatar
Transmission: wc T5
gonna pull the plugs tomorrow replace and its due for oil change too.
whats a CTS? good point about the cat probably due for a replacement anyway.
there are no codes
Old Jan 12, 2013 | 08:51 AM
Coolant Temp Sensor
Those often fail such that they tell the computer that the engine is WAY cooler than it really is, which makes it feed too much fuel.
Old Jan 12, 2013 | 08:56 AM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
Good little guide:
http://www.salemboysauto.com/original-faqs/faq-20.htm
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
