Building a bracket car??? Cam help......
Old Jan 14, 2013 | 08:55 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
89 rs, stripped 3.23 gears, 2500 stall...Weight is around 3300 lbs.Motor is 1998 5.7 vortec..Eddy rpm airgap intake, 750 holey... got all the boltons, ignition, headers, etc...Car suspension is set up for the track...Am wondering what would be a good cam choice for this type of vehicle...Am running 700r4...Gear will be changed soon to the 3.73 area...Will be glad to provide more details if needed..Please chime in with any thoughts..Thanks very much, Tom
Old Jan 14, 2013 | 10:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Building a bracket car??? Cam help......
It's been a long time since I fooled with those heads but if my memory is correct I think you may be limited to around .500" lift. I had a friend running a .525" lift cam on a dirt car with vortec heads. I never saw him race but it seemed strong.
Old Jan 14, 2013 | 10:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need to start with a cam then build everything around it. Since you already have a lot of parts, you're going to be limited to what the cam can do with those parts. Any sub par component will restrict the potential of a cam. You're biggest limiting factor right now is the converter stall. The stall speed is to get the engine rpm into the powerband as quick as possible at WOT. Too low or high and you lose performance. You're now limited to a camshaft that will work best with your stall speed which means other parts may not be optimal.
Is this street/strip or strip only? Parts selection will depend a lot on that.
Old Jan 14, 2013 | 10:55 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
[QUOTE=skirkland1980;5464938]It's been a long time since I fooled with those heads but if my memory is correct I think you may be limited to around .500" lift. I had a friend running a .525" lift cam on a dirt car with vortec heads. I never saw him race but it seemed strong.[/QUOTE
We are having the guides cut down so lift will not be a problem..Yes 2500 is kinda low on stall ran a 3500 on my 10 second dodge, but do not know alot about chevy camshafts, any ideas on what would go good with this combo...This motor will only be in for a while..thanks
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
