idle problems help!!!
Old Jan 16, 2013 | 06:29 PM
sturdybirdy's Avatar
Car: Firebird '88 Formula
Engine: 305 h.o. tbi
Transmission: 5 speed manual
Axle/Gears: standard diff 2.73
Hi there. I have a 1988 firebird formula, manual 5 speed tranny and a 305 h.o.
TBI injected engine. When it starts from cold, the idle will go to 2500 rpm and stay that way for quite a while(like choke sticking). Then will run ok but has a rough idle when warm and at a stop...it won't really quit but seems to not run on all 8 cylinders and rpm's drops below 450 then oscilates to 900 then back down again...engine will then hesitate when i give it gas. The engine temperature is descent but this only happens when engine is warmed up. I did change the IAC valve and I also changed the throttle body gasket because I detected a air leak(using the old carb cleaner trick). I am getting bad gas milage too.I am now a little stumped and wondering if the EGR valve is bad or maybe the O2 sensor...What do you think!!!
Old Jan 17, 2013 | 06:43 AM
ex-x-fire's Avatar
Re: idle problems help!!!
Disable the egr valve by plugging the vacuum hose that goes to the valve, drive it a couple of days to see if it acts up.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
