1988 2.8l idleing problem
Old Jan 17, 2013 | 11:22 PM
birshking's Avatar
Car: 1985 camaro iroc z-28
Engine: 5.7L
hello, i have a 2.8l f.i. camaro that will start. run. but will die unless you give it gas. it wont idle. and if i can hold it at 2000 rpms it runs rough. i need help to figure this out. thank you
Old Jan 18, 2013 | 06:18 AM
ex-x-fire's Avatar
Re: 1988 2.8l idleing problem
Remove the throttle body & clean it really well, esp the iac valve.
Does the engine have a higher idle when cold?
Egr valve might be sticking open.
Old Jan 18, 2013 | 10:06 PM
birshking's Avatar
Engine: 5.7L
What is an iac valve? And where is it located? Sorry I'm not to familiar with this arcanum
Old Jan 18, 2013 | 10:07 PM
birshking's Avatar
Engine: 5.7L
Also on cold starts the car will just start and then die.unless i catch it before it dies and give it gas.
Old Jan 19, 2013 | 04:50 AM
ex-x-fire's Avatar
Iac is no. 70. So it never idles fast, that part might be bad, it allows air to bypass the throttle blade by screwing in & out. Iac= idle air control valve.
Old Jan 19, 2013 | 03:31 PM
birshking's Avatar
Engine: 5.7L
ok, ill have to clean this and give it a go! will update, thanks. hope this works
Old Jul 12, 2014 | 06:18 PM
birshking's Avatar
Engine: 5.7L
ok, been away from this car as i also have an 85 camaro going under huge make over. taking out 305 to put in a 383 with hsr.
well i replaced the egr valve/gasket, iac valve. cleaned the tb. and still revs high at start up and then low and tries to stay alive by reving up and dies a few seconds later unless you give it some gas. so no changes occured before the egr and iac change. vacuum looks good.
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
BurlyChev
Aug 16, 2015 09:08 PM
