View Poll Results: Which is better Fuel injection or carburetors
Fuel Injection
66.67%
Carburetors
33.33%
Voters: 12. You may not vote on this poll
SURVEY help me out!
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
SURVEY help me out!
So for a research paper i'm doing I need 5 sources and would like one to be a survey, my topic is why fuel injection is better to use than carburetors, just vote and it would be awesome if you posted your opinion as well, thanks in advance guys!!
(My sub topics are fuel injection is efficient, modern technology, good for swapping/building...etc)
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: SURVEY help me out!
Question needs better definition.
For what use or under what conditions?
Generally EFI will kill everything else for overall perf , economy and general driveabilty in all conditions but there
are situations where some consider a carb may be the better choice for peak power /WOT operation especially if cost is a factor.
A interesting, if slightly biased ( carb seller ) perceptive
http://www.pro-system.com/scoop92102.html
