hose sucking air? Where does it go
Old Jan 12, 2013 | 07:22 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Hi, well i just put on a set of chrome valve covers and 2 oil breathers on my 350 tpi , and the one on drivers side is hooked up to the old pvc hoses line, and the passengers side doesnt have a mount for a hose line.
So i blocked off the old hose, but ever since i bought this it has a hose near the pcv valve that sucks air in when my motor is running and it sucks hard, anyways what is it, and should i just plug it up as it still runs fine with it plugged, thanx.
Old Jan 12, 2013 | 08:08 PM
Damon's Avatar
Re: hose sucking air? Where does it go
The "big" vacuum port on the carb should go to a PCV valve in one of the valve covers. The other valve cover should have a breather in it. If they're aftermarket valve covers you'll need a different sized grommet to mount a PCV valve (3/4") than you will to mount a breather (1").
Honestly, a picture would be worth a ton in this case. I'm not at all certain what hose you're referring to that would be giving you this vacuum leak.
Old Jan 12, 2013 | 08:23 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Ill try to take a picture tommoro, but i already installed the breathers, and the one on driver side where the old stock pcv valve went has a oil breather with a tip on top for a hose connectin which i hooked up to the old line without the valve part on end, you get what im saying?
Old Jan 13, 2013 | 07:01 AM
Damon's Avatar
I think I understand- I'm guessing you installed a "Mopar-style" breather. If so, that shouldn't be used in replacement of a PCV valve. Typically they are used to allow connection of a vapor line over to a remote "puke can". Definitely shouldn't have the PCV hose connected directly to the nipple on top.
Old Jan 13, 2013 | 09:27 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
so what do i do, where i can use this filter still?
Old Jan 13, 2013 | 09:30 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
Here is 2 pictures of the 2 that i bought and am using, so it gives you a better ideal
Attached Thumbnails hose sucking air? Where does it go-1109323794734040_1.jpg   hose sucking air? Where does it go-1307935226364040_1.jpg
Old Jan 13, 2013 | 09:45 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
It either goes to the pcv valve or the break booster if you have no pcv valve on the drivers side . remove your chrome aftermarket breather and use the old gromet from the old valve covers and put it in yours . then install pcv valve.
Old Jan 13, 2013 | 11:36 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
well i actually did that with the old pcv now lol, and the hose im talking about starts at the pleneum on pasenger front side and its the lower hose below the hose that goes to the passenger valve cover, so what is it then and where should it go
Old Jan 13, 2013 | 02:05 PM
Car: 1990 z28
Engine: 5.0
we realy need a pic or 2. what eng do you have? I,m assuming you have a carbed 305. and when you say plenum , did you mean intake? or do yoy have a tune port motor , tough to troubleshoot without some specs/ pics.
Old Jan 15, 2013 | 12:19 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
no im pretty sure its a 350 tpi, and i really would be mad if its a 305, but i cant get t the blocks number so i will never really know i guess.
Old Jan 19, 2013 | 11:59 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
So I brought this thread back so i could figure out for sure if its my brake booster cable, or what and what to do with it, and its the hose that is on the passenger very front side of the motor, and its directly beneath another hose, oh and their near the throttle body if that helps,
Old Jan 19, 2013 | 12:53 PM
Damon's Avatar
It doesn't. A picture or two is the only thing that's going to help at this point.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
