fuel pump
Old Jan 20, 2013 | 04:02 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
fuel pump
i recently installed a new fuel pump, it worked, then i had to replace the tumbler and starter, the car sat for about a month and after i did that i cranked over the motor but no fuel pressure, all fuses good, fuel pump relay is new, but not getting any power, ran 12v straight to pump and pump kicked on. pulled the computer out. and written on the computer is 1990 caprice 5.7 chp car. i have a 88 iroc. i checked the orange wire all the way back to the computer and no volts there....im assuming that this is the bad computer or does power come from a different leg of the harness?
Old Jan 20, 2013 | 08:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump
Originally Posted by mb2hurley
i checked the orange wire all the way back to the computer and no volts there...?
Orange wire at pump relay doesn't go to the computer
The computer operates the relay which supplies power on the orange wire from the batt through the relay
to the pump
In any case the stock oil pressure switch will ( should ) run the pump as soon as you crank the engine over
( your OP switch is working isn't it ? ) .This a backup to run the pump should the relay fail.
So if it the pump doesn't run when engine is cranked likely you have blown the fuse on the feed wire which
supplies both the relay and the OP switch
Should have 12V on the org wire at relay ( and OP switch ) all the time with the key off
Old Jan 20, 2013 | 09:01 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: fuel pump
Does you car have the VATS key? (the key with the black
pellet on the shank)
If it does and you installed a incorrect key/ignition cylinder
the anti-theft system activates and shuts off the electric fuel
pump.
Just a thought......................
Old Jan 21, 2013 | 03:47 AM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: fuel pump
my orange wire doesnt have voltage on or off, no power at all to that orange wire to the relay. and i dont believe it was, but i cant remember off hand, the old key is still stuck in the old tumbler
Old Jan 21, 2013 | 05:03 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: fuel pump
If it does and you installed a incorrect key/ignition cylinder the anti-theft system activates and shuts off the electric fuel
pump.
VATS shuts off the injectors and starter only; fuel pump will continue to work
Old Jan 21, 2013 | 05:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: fuel pump
Start here
https://www.thirdgen.org/forums/elec...e-problem.html
https://www.thirdgen.org/forums/elec...line-fuse.html
https://www.thirdgen.org/forums/elec...t-battery.html
If you replace the inline fuse and it keeps blowing
Read
https://www.thirdgen.org/forums/elec...eeds-help.html
Old Jan 21, 2013 | 08:08 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: fuel pump
awesome!! ill check all that tomarrow
Old Jan 22, 2013 | 11:32 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: fuel pump
ok quick question, just to be 100% i did find a fuse behind my fender that was blown, replaced it and had power to my fuel relay, but still nothing to the pump, took the connection off my oil pressure switch and jumped it and bam, fuel pump on, even with key on off position, so bad OP sensor right?
Old Jan 23, 2013 | 06:55 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: fuel pump
You know the pump only runs through the relay for 2 sec when the key is turned on , then relay shuts off until
the engine is cranked over?
Switch not sensor
OP switch should close and power the pump with cranking oil pressure (4 psi + )
Disconnect the relay , crank engine over ,pump should run. If it doesn't consider the OP switch faulty.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
