Help, Stranded, Need Advice.
Old Jan 21, 2013 | 04:43 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Me and a friend are stranded on the side of the interstate, im using my cell phone to type this, but my heater core went out.
I know this because steam is coming out of my air vents(whichever i have turned on) Its cold outside, and my car is overhearing, i used a case of water i had in the back(luckily) and filled the radiator and resivoir.
I need to know, is there a way i can drive it home and keep the heat down???
I live 6 miles away.
Old Jan 21, 2013 | 04:58 AM
Jk_Under's Avatar
Engine: 305 5.0L
Re: Help, Stranded, Need Advice.
anyone know? i don't have roadside, and its 5am
Old Jan 21, 2013 | 05:09 AM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
if possible, try to bypass your heater core by connecting the feed hose with either the return hose, or connecting it where the return hose goes.
Old Jan 21, 2013 | 06:39 AM
ex-x-fire's Avatar
Or clamping both heater hoses off w/ visegrips.
Old Jan 21, 2013 | 10:45 PM
Jk_Under's Avatar
Engine: 305 5.0L
i drove home just fine with water in the radiator, wheres the heater core located, is there a way to clamp off the hose without removing my dash and all?
Old Jan 21, 2013 | 11:17 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You do it from under the hood. You know you will have no heat if you bypass the heater core though.
Old Jan 22, 2013 | 02:20 AM
just fix the core dude, a lot of people gripe about it, but it isn't that bad. All you have to do is pinch the coolant hoses running to the firewall on the passenger side, pull them off of the tubes that they slip onto at the firewall, then pull your dash cover off, and take the heater unit cover off from under the dash. Once the covers are off it should be pretty self explanatory what you have to do to pull the heater core out. It shouldn't take you more then 2 hours to swap out, and its not very expensive to do so. PLEASE don't leave your car without a working heater, enough of these cars are hacked up as it is.
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
KCG
Sep 23, 2015 09:05 AM
mrdevontay
Sep 2, 2015 08:04 PM
masonta
Sep 1, 2015 06:40 PM
